Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2004 > 125amp fuse...
Author Thread: 125amp fuse...
Username: Napalmz
MIDWEST
Post Number: 42
im just wondering since the recommended fuse size for 4ga wire is 125a would it be possible to use a 150a or even a 100a being that i just cant find exactly a 125a anl fuse??
Username: Glasswolf
NorthWest, Michigan
Post Number: 5535
actually 4ga cable is good for up to 125A peak.
you should match the fuse to the current draw of your amplifiers.
I'd stay under 125, so 100A at most is good.
remember even a 100A fuse takes a max of 4 minutes to burn through at 200% load, so you're still very much in a safe zone there.
Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2004 > 125amp fuse... [ « Previous ] [ Next » ]
