Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through November 17, 2004 > Coaxials in stock components spot?
Author Thread: Coaxials in stock components spot?
Username: Boopers
Lima, Ohio
United states
Post Number: 264
if I put a set of coax 5.25" in to replace my stock components will it get the full range of sound or do I have to do something so that it will get full range frequencies?
Username: Glasswolf
NorthWest, Michigan
Post Number: 5498
you should get the full range the speakers and source are capable of..
you're not going to improve bass response though if that's what you're after.
you need at least a small powered sub for that.. especially on factory systems
Username: Boopers
Lima, Ohio
United states
Post Number: 265
the 512i infinity coax speakers I put in are only temporary until my Alpine TypeR mid's get here. I have a set of cheap tweets coming to replace the stock tweets too. At least until I can find a set of alpine typeR tweets. at least mounting depth won't be an issue in my doors.
Username: Blownriv
OH
Post Number: 30
there are advantages to using coaxials. one benefit is that the tweeter and mid are so close together. you get a near perfect point source, avoiding potential time alignment problems that can degrade the realism of your music.
but coaxials can't usually make strong midbass like components can. it's a trade off.
Username: Jonathan_f
GA
Post Number: 2600
Coaxials generally don't have a good crossover either, and poor designs can cause the tweeter's location to interfere with the mid. Well designed coaxials are nice, such as the Eclipse point source coaxials and the CDT braxials (those are more or less components, though). Component tweeters can be made to be even closer to proper phasing if installed correctly, it's just that most people usually put the mids in stock locations and the tweeters up very high in the a pillars or upper door.
Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through November 17, 2004 > Coaxials in stock components spot? [ « Previous ] [ Next » ]
