Thread: Anyone have MA Audio experience or opinion? |
| Posted on Thursday, November 04, 2004 - 02:22 pm: |
I have heard MA Audio makes good amps at a reasonable price. Are they reliable and how true are their watts ratings? |
Bronze Member Username: Carguy
Post Number: 50 Registered: Nov-04
| Posted on Thursday, November 04, 2004 - 02:54 pm: |
I am not sure about other models but the one I find worth buying is HK597. It is a 4 channel amp that's 200W rms at 4 ohms, 400W rms at 2 ohms per channel. I am currently using MA Audio's 18" sub. It is wicked. |
Silver Member Username: Joe718
Brooklyn,
NY
Post Number: 182 Registered: May-04
| Posted on Thursday, November 04, 2004 - 05:48 pm: |
thers are better amps out ther for the buck. |
Post Number: 61 Registered: Nov-04
| Posted on Thursday, November 04, 2004 - 08:14 pm: |
Hey Joseph if you can find an amp that's better for the buck compared to MA Audio's HK597 model, I'd surely like to know. |
Brooklyn,
NY
Post Number: 189 Registered: May-04
| Posted on Thursday, November 04, 2004 - 10:21 pm: |
well i can get the kicker kx850 for about $230 and the rockford fosgate 850 for about $220. I have just had alot of experiece with the chrome amps in my day lol. They just dont perform as good as products that the pros or semi pros use. |
Post Number: 72 Registered: Nov-04
| Posted on Thursday, November 04, 2004 - 11:43 pm: |
Hey Joseph, that kicker amp is a nice one but only one problem. It's a 2 channel amp. The MA Audio was 4 channel at 400W rms x 4 at 2 ohms. If you could get that for $230, it's a great deal. Some are charging $600! I wouldn't try any other MA model except HK597. |
New member Username: Xtorm
Post Number: 9 Registered: Oct-04
| Posted on Friday, November 05, 2004 - 12:24 pm: |
higher watage dun really mean it is powerfull rite..... genesis series 3 4 channel only hav 50w rms per channel..... hope i'm not wrong..... |
Post Number: 87 Registered: Nov-04
| Posted on Friday, November 05, 2004 - 02:09 pm: |
Hey Ivan, higher rms wattage means the amp can put out more power. |
Bronze Member Username: Xtorm
Post Number: 11 Registered: Oct-04
| Posted on Friday, November 05, 2004 - 08:39 pm: |
i mean power interms of the ability to drive the speaker.....tat genesis wack the speaker pretty nice while my cheapo 100x2 cant do the job good enof. juz my xperiance..... |
| Posted on Friday, November 05, 2004 - 08:40 pm: |
