Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2004 > MG ZR power wiring
Author Thread: MG ZR power wiring
Username: M_westney
Where is the best possible place to feed the power wire into the car from the engine bay on an MG ZR? Any experience of fitting?
Username: Carguy
Post Number: 53
Not sure if this helps but every car has a hole in the firewall. That is a good place to start.
Username: M_westney
yeah im sure i'll find a suitable place, just wondering if anyone had any past experince, save me a bit of time hunting around under the bonnet. cheers anyway.
Username: Deathshadow
Post Number: 178
Not every car has a hole... Mine sure didnt hehe :-) Drilling your own is more interesting anyway and you can put it where you want it O_O! w00h00
Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2004 > MG ZR power wiring [ « Previous ] [ Next » ]
