Home > Message Board > Car Audio > Amplifiers > Archive through November 04, 2004 > Best subs for my ...ALPHASONIC PMA 2300
Author Thread: Best subs for my ...ALPHASONIC PMA 2300
Username: Imstillhere
Michigan
HI I WAS WONDERING WHAT WOULD BE THE BEST SET OF SUBS FOR MY ALPHASONIK 23OO. I BOUGHT IT ABOUT 1 MNTH AGO FOR $7OO...I AM DEFINITLY GOING WITH 12'S SO...HELP ME 300Watts x 2 @ 4 ohms Stereo
500 Watts x 2 @ 2 ohms Stereo
1000 Watts x 1 @ 4 ohms Mono
Michigan
Post Number: 7
PLESEI NEED HELP SAME THING.....
Michigan
Post Number: 9
I WAS THINKING ALPINE FROM CIRCUIT CITY 2 OF THE TYPE E'S
Username: Carguy
Post Number: 36
Whoa, you paid $700 for the amp? I only paid $400 for my 2000W 4 channel amp. Anyways, your amp listing says you get 1000W at 4 ohms, so if you have 2 subs, make sure it's 2 ohms each, that way you can connect them in series to meet the amp's spec. You really don't need 2 channels for subs, one is the best.
For speakers, I'd get anything that's at least 30% higher in power compared to the amp. You see if you turn up the bass, the amp will supply more power than rated (peaks). I personally bought MA Audio 18" 1000W rms sub. Even with a 400W sub amp, it really pounds the speaker. You'll find that a speaker with ample power reserve produces much tighter bass than the one being driven to the limit.
Username: Jonathan_f
GA
Post Number: 2579
How much do you have to spend on subs?
Home > Message Board > Car Audio > Amplifiers > Archive through November 04, 2004 > Best subs for my ...ALPHASONIC PMA 2300 [ « Previous ] [ Next » ]
