Thread: Legacy amps......any good? |
Bronze Member Username: Randy420
Post Number: 39 Registered: Dec-03
| Posted on Wednesday, November 03, 2004 - 07:00 pm: |
did anyone ever hear of legacy amps..im buy'n one off e-bay for $144, it 2400 watts and i want to is to push 2 kicker 1200w each would that amp be good with those subs?...i'm not looking for perfect sound, but anything that will be better then my 1000w db+ sub
| Posted on Wednesday, November 03, 2004 - 07:18 pm: |
nah get something different, ask anyone legacy are bullshit... |
reference guy Unregistered guest |
| Posted on Friday, November 05, 2004 - 09:11 pm: |
legacy is garbage. when buying an amp you got to buy by rms power. Also look up damping, thd rating, and s/n ratio on google and you will find out what these mean and you can use these to help. A 1000w of legacy power can actually kill a woofer because of distortion. Think of it like having a 500 horse power motor in a yugo and having it in a ferarri. Power is nothing with out control and cheap as amps can control the power they put out. |
Post Number: 40 Registered: Dec-03
| Posted on Saturday, November 06, 2004 - 08:07 pm: |
so what amp(s) would be best for two kicker S10L7?.. |
NorthWest,
Michigan
Post Number: 5536 Registered: Dec-03
| Posted on Saturday, November 06, 2004 - 09:21 pm: |
what sort of budget are you working with for the amplifier? that's the best way to start.
Post Number: 41 Registered: Dec-03
| Posted on Sunday, November 07, 2004 - 01:05 pm: |
just $600-700...i was going to buy 2 kx.1200 amps from kick but their like $800 for one
NorthWest,
Michigan
Post Number: 5555 Registered: Dec-03
| Posted on Sunday, November 07, 2004 - 02:09 pm: |
get two JBL BP1200.1 amps 1200 watts RMS x 1 @ 2 ohms each $200 each from cardomain.com on sale. usually about $350 each
Post Number: 42 Registered: Dec-03
| Posted on Sunday, November 07, 2004 - 04:54 pm: |
ok thanks..i'll take a look at them |
Post Number: 43 Registered: Dec-03
| Posted on Sunday, November 07, 2004 - 05:08 pm: |
i could find any JBL but hows BOSS..its 1500w rms and 3000 peak? any good (dont need perfect SPL) |
Silver Member Username: Chevy_for_life
Post Number: 191 Registered: Sep-04
| Posted on Sunday, November 07, 2004 - 05:46 pm: |
OK BOSS SUCKS!!!..Next time you get an Idea of some brand that sounds too good to be true search the message boards before posting a new thread |
Post Number: 44 Registered: Dec-03
| Posted on Sunday, November 07, 2004 - 10:00 pm: |
well i did check the reviews and people gave it 5 stars |
