Home > Message Board > Car Audio > Amplifiers > Archive through November 04, 2004 > Best amp for this sub? ( 15" kicker l...
Author Thread: Best amp for this sub? ( 15" kicker l5)
Username: Pcgamer02
Post Number: 11
I'm gonna buy one of these babies off ebay today. Its refurbished by kicker, hopefully it will be good. I have a choice of 2ohm DVC or 4ohm DVC. Im leaning toward 2ohms so I can run a 1ohm load. What do you guys think would be the best Class D amp for this sub? Im not 100percent set on this particular sub, but I am set on a solo-baric seris sub.
Username: Pcgamer02
Post Number: 12
Forgot to mention some of the amps I was thinking of
Kicker KX600 600 watts RMS x 1 at 2 ohms
Hifonics NX750D Nemesis Class-D Series
750W RMS x 1 at 1 ohms • 1 ohm stable monoblock
Sub can handle 750watts rms.
Username: Djzavala
Whittier, Ca
Post Number: 76
I would go with the kicker amp because it just complimentz the sub you are getting. i also believe that amp gives you more pop in it. yo should go with the 2 ohm DVC, its just better,
Username: Pcgamer02
Post Number: 13
If I get 1 2ohmDVC I can't wire for a 2ohm load. I would have to get a 4ohm DVC vr of the sub.
Username: Jtw320
Saginaw, MI
question related to this, if you had two subs both 2ohm DVC kickers can u then wire them to a 2ohm load? and would the JBL BP600.1 be a good amp for two 12-inch Kicker CVR's with Dual 2ohm Voice Coils?
Username: Pcgamer02
Post Number: 14
Jason check out this,
http://www.rockfordfosgate.com/rftech/wiringwizard.asp
Home > Message Board > Car Audio > Amplifiers > Archive through November 04, 2004 > Best amp for this sub? ( 15" kicker l... [ « Previous ] [ Next » ]
