Thread: Confusing amp situation. Can't figure it out. |
Bronze Member Username: Stamant
Pensacola,
FL
Post Number: 16 Registered: Sep-04
| Posted on Tuesday, November 02, 2004 - 08:54 pm: |
Jonathan, Glass, or someone intelligent. Here is the situation. I have tried to figure this out on my own and I just am getting frustrated. I do not know what kind of amp to purchase for my system. So far for speakers I have MB Quart RCE 216 component speakers, MB Quart Coaxials, and two 10" Kick comp subs which are SVC at 8 ohms. The amps I have are an older PPI 2x 150W at a 4 ohm load and a Pioneer 4 channel 35Wx4. I know I need to buy another amp but which amp do I run to what speakers? Would you buy another amp for the subs and if so what kind exactly. Please help with your opinions as I am losing direction. Thanks. Paul |
NorthWest,
Michigan
Post Number: 5431 Registered: Dec-03
| Posted on Wednesday, November 03, 2004 - 08:18 am: |
you could just use the pioneer 4ch amp for the MBQ components, and bridge the PPI amp to mono and run the two subs in parallel on that you'd be all set
Bronze Member Username: Carguy
Post Number: 29 Registered: Nov-04
| Posted on Wednesday, November 03, 2004 - 05:10 pm: |
Hey Paul, bridging the PPI amp should give you more bass power. I'd get a stronger 4 channel amp instead. Pioneer amps aren't that great. Besides 35W is not much compared to your HU. I have 100W x 4 rms driving my front and rear speakers. They sound very clean even at high volumes. |
