Thread: Why no rear speakers? |
j-dub dub Unregistered guest |
| Posted on Tuesday, November 02, 2004 - 02:08 am: |
i have been reading through the posts and i see a lot of advice to not have any speakers in the back. i have an extened cab f150. i took the back seat out and put 4 12" kicker comp vr subs and 2 RF 6x9s in its place. i have 5.25" speakers in the front doors (which i will be upgrading to 6.5" as soon as i figure out how to). is there a reason that i should get rid of the rear speakers? or even turn them down? i dont understand the logic behind this. can someone please explain? |
| Posted on Tuesday, November 02, 2004 - 02:14 am: |
sorry for the double post...im an idiot |
Gold Member Username: Jonathan_f
GA
Post Number: 2554 Registered: May-04
| Posted on Tuesday, November 02, 2004 - 02:18 am: |
http://www.teamcaf.org/geolemon/Phasing/Multiple.htm |
#54danny#54 Unregistered guest |
| Posted on Wednesday, November 03, 2004 - 06:06 pm: |
jonathan...what amp do u suggest 2 get 4this... Subs=2 15"Sony XSL151P5 Detailed Description of the XSL151P5:price:$106.95 XSL151P5 Sony XS-L151P5 15" Component Subwoofer (Sold Single/ Not Pair) Five-sided polypropylene cone Frequency response 15-2,000 Hz Power range 50-400 watts RMS Peak power handling 800 watts Sensitivity 89 dB Top-mount depth 7-1/4" Sealed box volume: 2.1 cubic feet Ported box volume: 2.5 cubic feet http://www.audio-warehouse.com/web/mdl/XSL151P5/detail.asp Speakers=Sony XS-V6950H 6"x9" 4-way speakers (Pair):price:$77.95 Detailed Description of the XSV6950H: XSV6950H Sony XS-V6950H 6"x9" 4-Way Speakers (Pair) H.O.P. woofer rubber surround 2-5/8" Nano-Fine (hybrid silica-polyamide compound) cone midrange 1" PEI balanced-dome tweeter 1" PEI balanced-dome supertweeter frequency response 25-32,000 Hz power range 2-100 watts RMS peak power handling 400 watts sensitivity 93 dB top-mount depth 3-1/8" Priced per pair http://www.audio-warehouse.com/web/mdl/XSL151P5/detail.asp
