Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through November 17, 2004 > Fitting 6.5" speakers into 5.25" hole...
Author Thread: Fitting 6.5" speakers into 5.25" hole
j-dub dub
Is there a converter that allows a 6.5" speaker to fit in a 5.25" hole. I can imagine what it would look like, but I cant find it on the internet. If there is no such thing, what should i use to cut bigger holes through the metal on my door? Would a jigsaw be a good idea? Please help.
Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through November 17, 2004 > Fitting 6.5" speakers into 5.25" hole... [ « Previous ] [ Next » ]
