Thread: So much bass that i cant hear the treble of my music.... |
| Posted on Monday, November 01, 2004 - 07:33 pm: |
i got a 4 channel 500 watt amp it is extremely loud it is so loud that when i have the vloume half way up my ears cant take the preasure, i got 1 15" kicker in a bandpass box and i got my 2 front speaker hooked up to it and i dont have my 6x9's hooked to it. How would i keep the sound in a way where i have a lot of bass and i still can hear my treble. |
Bronze Member Username: Ctx
Post Number: 88 Registered: Jun-04
| Posted on Monday, November 01, 2004 - 08:50 pm: |
umm turn down the bass boost on your deck and your amp? |
NorthWest,
Michigan
Post Number: 5406 Registered: Dec-03
| Posted on Monday, November 01, 2004 - 09:29 pm: |
you need a strong front stage component set, and an amplifier for those speakers if you want to balance out the sub.
| Posted on Monday, November 01, 2004 - 09:39 pm: |
what do you mean strong front component stage, i am not very knowledgable about car audio, i got 2 switches on the amp that sais fer each set of the channels like on the front speakers it sais bass boost on or off i have that on off and have the gain for that full and for the rear channels it sais the same but i have the bass bosst switch on and the gain like half way and when i turn the bass bosst on and put the gain on it full than everything balances out but its not as loud as i want it to be, maybe its because i have it to the factory deck of a toyta camry 01? |
Damien R. Unregistered guest |
| Posted on Monday, November 01, 2004 - 09:48 pm: |
Is the problem just in the front? Toyota makes the front speakers A LOT lower for safety reasons I supose. My camry was unbalanced until I replaced the factory wires and put in a 4 channel amp. The gauge they use for the front speakers is a lot more lower then the rears. |
Bronze Member Username: Lbeckner
Tulsa,
Ok
Usa
Post Number: 13 Registered: Oct-04
| Posted on Monday, November 01, 2004 - 10:51 pm: |
fade front to back on your deck maybe? |
Bronze Member Username: Carguy
Post Number: 14 Registered: Nov-04
| Posted on Tuesday, November 02, 2004 - 03:26 pm: |
Whoa, never heard of a guy complaining about too much bass before. If you're getting too much, try the tone controls on your HU or if your amp came with a remote bass control, turn it down a bit. I personally have 3 seperate amps, one for the front, back and sub. No matter how loud I crank up my bass, it never over powers my front (highs) cause of extra speakers I installed plus it's own amp. |
Silver Member Username: Joe718
Brooklyn,
NY
Post Number: 174 Registered: May-04
| Posted on Tuesday, November 02, 2004 - 11:28 pm: |
See most of your voals com from the front of the car so what he menat by having a strong front stage is just improve the sound from up front. When you do that you get more clarity. get a nice component set and an mpto powee them adjust your bass and you should be straight. |
