Thread: Need replacement tweets |
Silver Member Username: Boopers
Lima,
Ohio
United states
Post Number: 243 Registered: Jul-04
| Posted on Saturday, October 30, 2004 - 11:46 pm: |
so I got me some alpine type r 5 1/4" mids for my front components and now I need to replace my stock tweeters. They are 1" and the mount for them has screws 3 1/2" apart corner to corner. Anyone know of a good replacement for these? |
Lima,
Ohio
United states
Post Number: 244 Registered: Jul-04
| Posted on Sunday, October 31, 2004 - 12:22 am: |
guess I could give a bit more info. the factory tweeter seems to be square, or actually it's a round tweeter in a square plastic holder. don't know much about this sort of thing but I'd like to put the replacement tweeter in the same spot if I can. |
Lima,
Ohio
United states
Post Number: 245 Registered: Jul-04
| Posted on Sunday, October 31, 2004 - 11:08 am: |
bump |
Lima,
Ohio
United states
Post Number: 247 Registered: Jul-04
| Posted on Sunday, October 31, 2004 - 03:08 pm: |
nobody knows of a good replacement that will go in my stock tweeter spot? |
Bronze Member Username: Xxkmfdmxx
Post Number: 30 Registered: Oct-04
| Posted on Sunday, October 31, 2004 - 09:52 pm: |
Well, I like useing the Cuspid TW-0160 tweeters, You can get them on ebay cheap http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=14943%26item%3D5728163743 &tc=photo Check 'em out, Don't know if this is exactly what you looking for but, Just refering a good pair of tweets |
Gold Member Username: Jonathan_f
GA
Post Number: 2531 Registered: May-04
| Posted on Monday, November 01, 2004 - 12:21 am: |
How much do you have to spend on the tweeters, where are they located? Also, what are you powering them with, what kind of crossover (if any) do you plan to use? Last, what do you like more, metal tweets (crisper, brighter sound) or soft domes (smoother, warmer sounding, a bit more natural)? |
Lima,
Ohio
United states
Post Number: 249 Registered: Jul-04
| Posted on Monday, November 01, 2004 - 09:56 am: |
stock components are in the door in the lower front corner, woofer towards the front of the car and tweeter behind it. price isn't really an issue I mean I don't want to pay 100 for a set of tweeters but I'd like a decent set. I will be using an amp for the components eventually but right now I'll just be running off my HU. I have crossovers already that come with the woofer part. either silk or metal would be ok, the ones that are in now are metal so I have no real preference there. |
