Home > Message Board > Car Audio > Amplifiers > Archive through November 04, 2004 > Humming sound comming from amp while ...
Author Thread: Humming sound comming from amp while the deck is off, y?
hi ppl i just hooked up my system in my car and i did the wireing on it my self too, and everytime i turn my stereo off like from the button on the head unit the subwoofers and the speaker all go hummmmmmmmmmmm, how can i fix that, is it because i connected the remote wire to my +12 volt ignition wire? and if it is how can i have the amp not humming when i want to turn the head unit off. My car is a toyota camry 2001
Username: Glasswolf
NorthWest, Michigan
Post Number: 5354
turn down the amp gain and see if it stops.
make sure power and signal lines aren't run together.
if it still does this, move remote trigger to a different 12 volt line/circuit.
i have tried to turn my gain down and nothing happened but when i turned my bass off from the channel on the amp that i have my subwoofer hooked on to it its a 15" kicker.
i have tried to turn my gain down and nothing happened but when i turned my bass off from the channel on the amp that i have my subwoofer hooked on to it its a 15" kicker. and i cant be bothered to go behind the deck to switch the 12v wire because im getting my head unit changed soon.
Home > Message Board > Car Audio > Amplifiers > Archive through November 04, 2004 > Humming sound comming from amp while ... [ « Previous ] [ Next » ]
