Thread: Help!!!! |
New member Username: Morgan
Post Number: 1 Registered: Oct-04
| Posted on Friday, October 29, 2004 - 11:20 pm: |
I have got a componenet set of speakers and they are not the same size as the old ones that are already in my car. They wont fit. How can i make them fit? ive heard that you can make a new door panel or something that you can create so it can hold you new speakers? any website or something that teaches you how to do this? help! can i do this? what else could i do? |
| Posted on Monday, November 01, 2004 - 04:13 pm: |
Don't make a new door panel, make the hole bigger with an electric saw, the door panel is made of plastic and you wouldn't be able to make one. |
| Posted on Monday, November 01, 2004 - 04:14 pm: |
