Home > Message Board > Car Audio > Amplifiers > Archive through November 04, 2004 > Is a JBL1200.1 overkill for 2 Kicker ...
Author Thread: Is a JBL1200.1 overkill for 2 Kicker CVR12s?
Biggs
Or should I just go with the 600, or is there something else I should look to (my budget is $300)
Thanks
Username: Boopers
Lima, Ohio
United states
Post Number: 234
the kicker cvr 12's are rated at 400wrms using dvc 4ohm you could run them on a 1200 if you run the vc's in series, you'd get a 4 ohm load on the amp, or if you dvc 2ohm and wired the subs series you'd get 2ohm load on the 600 giving them 300wrms a piece. you may be able to get an amp that's more matched, look for a 800.1 or so to run them. but you can get the 1200.1 or 600.1 for less than you'd get a good 800.1 amp.
Home > Message Board > Car Audio > Amplifiers > Archive through November 04, 2004 > Is a JBL1200.1 overkill for 2 Kicker ... [ « Previous ] [ Next » ]
