Home > Message Board > Car Audio > Amplifiers > Archive through November 04, 2004 > 1 jl w3
Author Thread: 1 jl w3
Username: Jlprix91
Muskegon, Mi
Usa
Post Number: 16
i had to w3's but one had a bad vc, i didnt wanna mess with it so should i buy another or just run an amp with one sub and aftermarket 6x9's and 4"s. what amp would be good?
Username: Jlprix91
Muskegon, Mi
Usa
Post Number: 21
need some help here?
Username: Glasswolf
NorthWest, Michigan
Post Number: 5287
run one sub for now if you want. you can replace the W3, or contact JL and they can rebuild the sub for a nominal fee as well. Cheaper than replacing the sub.
Home > Message Board > Car Audio > Amplifiers > Archive through November 04, 2004 > 1 jl w3 [ « Previous ] [ Next » ]
