Home > Message Board > Car Audio > Amplifiers > Archive through November 04, 2004 > Good mono amp for two 12"solo barics?...
Author Thread: Good mono amp for two 12"solo barics?
MillaLite
I just got two L5 12" solo barics and the put out 600 RMS and 2 Dual voice coil. What is a good amp that will power both of them. I was lookin at the Audoibahn A1500HCT and the Rockford Fosgate T1001bd. Help me out on what to get. Dont plan on spending more than 600 on the amp.
Username: Igotpenguinz
Mi
Post Number: 24
what ohm? I have 2 12 L7 DVC 4ohm and i had a 1300HCT mono. audiobahn isn't known in this forum to be outstanding but if your going to go with audiobahn get 2 1300hcts if your 4ohm cause you can make the load 1ohm with parallel/parallel (I think) the price would be a little under 600
Username: Insearchofbass
Post Number: 999
There really are amplifiers that will do the job for alot less but we need to know what ohms per voice coil your L5's are?
Post Number: 1000
oh i see if your saying 2 ohm dual voice each go with the jbl 1200.1 for a 2 ohm load. Heres one on ebay but you might find a good deal elsewhere on the web too.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5728236348 %26%26
Home > Message Board > Car Audio > Amplifiers > Archive through November 04, 2004 > Good mono amp for two 12"solo barics?... [ « Previous ] [ Next » ]
