Thread: HU with the most control |
| Posted on Thursday, October 28, 2004 - 06:27 pm: |
Is there a head unit out there where I can control the crossovers. I want to experiment with rear fill, midbass. I also would rather have my crossovers done digitally at the HU instead of some tiny knob on the amp or some external crossover. I know alpine has something like the mean freequency setting for a channel. What brand of HU offers the most prcise control.? I am more of a Home audio guy and was wondering if car audio can offer the same control. Glass? thanks |
Bronze Member Username: Bananakrill
Post Number: 11 Registered: Jul-04
| Posted on Thursday, October 28, 2004 - 06:59 pm: |
I have the Eclipse CD8454. There are all kinds of equalizer settings and two modes - pro mode and easy mode for your equalizers and time alignment. It's a great HU even though I don't really use the pro mode. I don't need it with the speakers I have. Crappy stock speakers. But I think it is like a 10 band parametric equalizer. |
Bronze Member Username: Elecgenius
La Puente,
Ca
United States
Post Number: 82 Registered: Oct-04
| Posted on Thursday, October 28, 2004 - 11:17 pm: |
Pioneer’s DEH-P7600MP its the best hu ive ever had man. it lets u control every speaker by isolating it and adjustin mids bass and highs for just that one speaker, best mp3 wma player ive seen by far. comes with a 4 volt pre amp 2-way crossover with 18dB/octave low-pass slope CD / MP3 / WMA Playback Detachable Flip-Down Faceplate MOSFET 50W x 4 Maximum Power XM Radio Ready with 2nd Generation Display Credit Card Sized Remote Included Optional Wired Remote Pop-Up Rotary Volume Control EEQ Performance Chip 3-Band Parametric Equalizer (Adjustable Level, Frequency, and Q Factor) Easy EQ (EEQ) switches 5 Factory and 2 User EQ Presets (Super Bass, Powerful, Natural, Vocal, Flat, Custom 1, Custom 2) Source Custom EQ Memory (Independent Custom Memory for Each Source) EQ-EX Feature For Enhanced EQ Effect SFEQ (Sound Focus EQ) Additional Independent Bass / Treble Control for Front and Rear NEW! BMX (Bit Media Expansion) Technology Digital Compression for MP3 and WMA Playback BMX1 Mode Enhances the Depth and Width of the Sound BMX2 Mode Improves the Sense of Presence Three Sets of 2-Volt RCA Preouts (Front, Rear, and Sub) Front/Rear High-Pass Filter (50/80/125Hz, 12dB/oct.) Selectable Low-Pass Filter (50/80/125Hz, 18dB/oct.) Sub-Out Level (-12dB to +12dB) with Phase Control IP-Bus System Control XM Satellite Tuner Ready CD Changer / DVD Control Auxiliary Input (CD-RB10 or CD-RB20 required) 2 External Unit Control S.L.A. (Source Level Adjustment) Selectable Fader Control Organic EL Display (128 x 33 pixel) Full-Motion 3D Graphic Animations Including 2 Screensavers 2 Level Meters and 4 Background Animations 16-Character Text Display with Adjustable Brightness Level White Backlight for Increased Contrast 24 x 33 pixel Auxiliary Display with Soft Key Feature Compact Disc: Disc/Folder Random Play Audible Fast Forward/Reverse Playback Compatible with Digital CD-R and CD-RW Disc Title Memory (48 Discs) CD Text and ID3 Tag Display MP3 / WMA / .WAV CD-ROM Playback 3-Beam Laser Pick-Up with AGC (Automatic Gain Control) 1-Bit D/A Converter with 8x Oversampling Anti-Shock Mechanism Radio: Supertuner IIID with Digital Processing Significantly Less Distortion Than An Ordinary Tuner Increased Signal-To-Noise (S/N) Ratio Reduced Multi-Path Noise Improved Sensitivity and Stereo Separation 24-Station / 6-Button (18FM / 6AM) Presets BSM (Best Station Memory) Up / Down Seek with Selectable Local Seek Tuning http://www.cardomain.com/item/PIODEHP7600MP got it for 200 bucks, hehe |
NorthWest,
Michigan
Post Number: 5273 Registered: Dec-03
| Posted on Thursday, October 28, 2004 - 11:22 pm: |
yup any high end eclipse or alpine unit would serve your needs. I personally prefer to use outboard processing for all of that if I can, but if you want it all packed into a head unit the Eclipse CD8454 may be a good bet for ya.
| Posted on Friday, October 29, 2004 - 02:45 pm: |
Thanks guys, I haven't looked into any eclipse stuff byt now I will. -D |
