Thread: Jonathan or Glasswolf or both?? |
Bronze Member Username: Igotpenguinz
Mi
Post Number: 21 Registered: Oct-04
| Posted on Thursday, October 28, 2004 - 05:55 pm: |
I still can't figure out what happened to my amp. Whenever I turn it on it makes this high intense constant noise. Did i blow it? I think it was when I was not thinking and messed with my amp when it was on. I was tightening a wire while it was on. (Don't be afraid to call me a dumbass.) If it is broken I geuss my audiobahn curse will be lifted. What should I get if this is broken? I have 2 12 kicker L7s DVC 4ohm |
Mi
Post Number: 26 Registered: Oct-04
| Posted on Friday, October 29, 2004 - 11:40 am: |
No one knows? Do i have a stumper? |
NorthWest,
Michigan
Post Number: 5300 Registered: Dec-03
| Posted on Friday, October 29, 2004 - 02:09 pm: |
check your wiring once more. remove one sub at a time to make sure one isn't blown, causing a short. after that, I'd figure either the amp is damaged, or the head unit's RCA pre-out stage is damaged.
Mi
Post Number: 27 Registered: Oct-04
| Posted on Saturday, October 30, 2004 - 11:28 am: |
What can I do to fix it? if it's the head units RCA? |
NorthWest,
Michigan
Post Number: 5316 Registered: Dec-03
| Posted on Saturday, October 30, 2004 - 11:54 am: |
send the unit in for repair take it to a radio repair shop replace it those are the options
Mi
Post Number: 28 Registered: Oct-04
| Posted on Saturday, October 30, 2004 - 12:05 pm: |
you know a good repair shop in michigan? close to Clarkston? |
NorthWest,
Michigan
Post Number: 5322 Registered: Dec-03
| Posted on Saturday, October 30, 2004 - 12:11 pm: |
Go to the manufacturer's website online and use their database for auth'ed repair centers based on location. You should find one close to you.
