Thread: RCA Interconnection Cable |
New member Username: Bumperjake
Post Number: 1 Registered: Oct-04
| Posted on Thursday, October 28, 2004 - 02:00 pm: |
My Current Head Unit only has the component outputs for one RCA cable and the REM. will my amp not work without the other cable? |
Bronze Member Username: Igotpenguinz
Mi
Post Number: 22 Registered: Oct-04
| Posted on Thursday, October 28, 2004 - 05:57 pm: |
I know my old tv only had one also. I just bought a 2 to one and connected both the RCA cables into it and plugged it in. (Don't know about car radios though.) |
NorthWest,
Michigan
Post Number: 5268 Registered: Dec-03
| Posted on Thursday, October 28, 2004 - 10:56 pm: |
head units with pre-outs should ALL have at least two RCA connections. one red, one white. if not, yours probably isn't a pre-out
Post Number: 3 Registered: Oct-04
| Posted on Thursday, October 28, 2004 - 11:15 pm: |
Mine has one red one white; they are connected at the amp like they are at the head unit. The REM is also connected. And the power source is hooked up. The indicator light on my amp is on. The sub is hooked into the amp also. Still nothing is happening. P.S. I still have one unused RCA cable that came with the wiring kit. |
NorthWest,
Michigan
Post Number: 5275 Registered: Dec-03
| Posted on Thursday, October 28, 2004 - 11:29 pm: |
check voltage with a test light or DMM at the amp at positive and REM. check ground using continuity on a DMM. see if ya have a good ground and 12VDC
