Thread: Would this work |
Bronze Member Username: Jlprix91
Muskegon,
Mi
Usa
Post Number: 13 Registered: Oct-04
| Posted on Thursday, October 28, 2004 - 10:10 am: |
I am getting a directed 500 amp should i get the 2 channel or the d amp, which one would push 2 jl audio w3 d4's 250 rms |
NorthWest,
Michigan
Post Number: 5233 Registered: Dec-03
| Posted on Thursday, October 28, 2004 - 11:19 am: |
single coil, 4 ohm subs? go with the class D amp. (mono)
Muskegon,
Mi
Usa
Post Number: 15 Registered: Oct-04
| Posted on Friday, October 29, 2004 - 08:05 am: |
dvc |
NorthWest,
Michigan
Post Number: 5289 Registered: Dec-03
| Posted on Friday, October 29, 2004 - 10:22 am: |
mmm if each sub has dual 4 ohm coils, you'll have two 2 ohm subs. You'll either want a two-channel amp, or two mono amps, or a single mono amp if it's 1 ohm stable. More amps today are being listed as 1 ohm stable, so that's worth a look. Kicker, JBL, Orion, PG, and plenty of others come to mind.
