Thread: Looking for a pair of 5x7/6x8 speakers |
Bronze Member Username: Xxkmfdmxx
Post Number: 21 Registered: Oct-04
| Posted on Wednesday, October 27, 2004 - 11:47 am: |
Which speakers would you reccomend for under $80(I'm buying them on eBay) They could be either 5x7s or 6x8s Also any reviews on the Pioneer TS-A6870R? I listened to these in a local audio store and they sounded quite well for $55 |
Bronze Member Username: Cruxis
PA
Post Number: 22 Registered: Aug-04
| Posted on Wednesday, October 27, 2004 - 09:03 pm: |
I have four of them. They work pretty well. However, for that amount of money, perhaps you should try for infinity speakers. |
Post Number: 22 Registered: Oct-04
| Posted on Wednesday, October 27, 2004 - 09:22 pm: |
Which Infinitys would you reccomend? I heard the 6802CF's are good, is this true? |
Post Number: 23 Registered: Oct-04
| Posted on Wednesday, October 27, 2004 - 09:24 pm: |
Also what about Alpines SPS570A? |
NorthWest,
Michigan
Post Number: 5245 Registered: Dec-03
| Posted on Thursday, October 28, 2004 - 11:49 am: |
Infinity Kappa 4x6 plates. those are about the best you'll find in that crappy speaker size.
New member Username: Tullphan
Post Number: 2 Registered: Nov-04
| Posted on Friday, November 12, 2004 - 12:51 am: |
I just got a 98 Crown Vic. My options for the front door are either 5 1/4", 5 1/4" components, or 5x7/6x8. What kind of mods are needed for a 4x6 plate to go in there? Thanks. |
| Posted on Friday, November 12, 2004 - 01:19 am: |
Go with the comps man...better sound quality and imaging. only thing worse than 4x6 are 4x10s Honestly...what were they thinking making 4x10's...
