Thread: Xtant or JL Audio Amp |
FlyFishin4trout Unregistered guest |
| Posted on Wednesday, October 27, 2004 - 10:39 am: |
I have an Xtant4004 amp that I am thinking about bridging to 200wattsx2. Would that be as nice as getting a JL Audio 300/2. I am not sure who makes the better quality amp. The speakers I will be using are Morel Hybrid Ovation 6's. Thanks for your help. |
NorthWest,
Michigan
Post Number: 5213 Registered: Dec-03
| Posted on Wednesday, October 27, 2004 - 06:49 pm: |
JL is the better amp. either one will be fine. both are good amplifiers.
NorthWest,
Michigan
Post Number: 5214 Registered: Dec-03
| Posted on Wednesday, October 27, 2004 - 06:50 pm: |
on a side note, for the cost, you'd be better off spending money on a different portion of the system for the best results for the money spent. you won't hear any drastic change, switching amps.
