Thread: How much WATTS does my amp need to be? |
New member Username: Crankdbass
Post Number: 2 Registered: Oct-04
| Posted on Wednesday, October 27, 2004 - 05:38 am: |
How much watts does my amp need to be if i want to run a 400 watt sub. and would my amp need to be mono or 2 channel, or doesn't it matter coz i'm not quite sure what the difference is! please help!!! |
Bronze Member Username: Jlprix91
Muskegon,
Mi
Usa
Post Number: 19 Registered: Oct-04
| Posted on Friday, October 29, 2004 - 10:14 am: |
If you want to run just one sub you can get a mono amp, or if running a full system you can choose a 2 or 4 channel amp, if the sub is 400 rms then any amp with that power rating should suffice or a 4 channel or 2 channel that you can bridge |
NorthWest,
Michigan
Post Number: 5286 Registered: Dec-03
| Posted on Friday, October 29, 2004 - 10:16 am: |
just for the record, you can run multiple subs from a mono amp. class D amps are most often mono, and made just for driving subs. You'll have a hard time finding any class AB multi-channel amp that can produce more than about 500 watts per channel RMS at it's minimum load.
