Home > Message Board > Car Audio > Amplifiers > Archive through November 04, 2004 > Confused on the wiring on my amp, can...
Author Thread: Confused on the wiring on my amp, can anyone help?
Username: Djzavala
Whittier, Ca
Post Number: 55
Im trying to set up my subs, but i dont know exactly how, looking at this diagram for a 4 ohm load i cant finish it.
http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp =Dual+Voice+Coil+-+4+ohms+x+2&image.x=21&image.y=15
i have a Fosgate Power 851s amp (2 channel amp). Im confused because in the picture there only ends up being 2 coonections to the amp, one positive, one negative, (because the subs where hooked up together to parallel or series, dont really know) but where do they go on the amp? my amp has 2 sets of positive and negatives (obviously the left and right speakers)
when you go to the link i have 2 subs, 4 ohm dual voice coil, and im trying to get them to a 4 ohm load.
Username: Igotpenguinz
Mi
Post Number: 17
Use this website
just put them both in it
Username: Northerncomfort
Sudbury, Ontario
Post Number: 8
wiring them together you wil only have one pos and one neg,use your bridged (pos on left chanel,neg on right channel,this wil give you max rms power
Home > Message Board > Car Audio > Amplifiers > Archive through November 04, 2004 > Confused on the wiring on my amp, can... [ « Previous ] [ Next » ]
