Home > Message Board > Car Audio > Amplifiers > Archive through November 04, 2004 > My setup
Author Thread: My setup
Username: Rsoares28
Scarborough, Ontario
Post Number: 16
finnaly got pics of my setup tell me what you think.... is that box to big for the type R????
[img]http://groups.msn.com/_Secure/0UgAeA2gZPSWo*Q5ALVOQJ!ROLShBrve3hxoEdS8oWXmGF7exBDhmKIbSVCV9tTUEh3hn1z9PonbxdIZnH!n933hD8pxA Drw8wAgXn0GK!bBUOAQxu01B*HXptcefJQQ4/Picture%20009.jpg?dc=4675494780558456372[im g/]
Username: Rsoares28
Post Number: 17
so..... how do u post pics?
Username: Rsoares28
Post Number: 18
here is the link to where my pics can be found
http://pg.photos.yahoo.com/ph/conceited_guy_18/album?.dir=bdaf&.src=ph&store=&pr odid=&.done=http%3a//pg.photos.yahoo.com/ph//my_photos
Username: Rsoares28
Post Number: 19
nobody has any advice?
Username: Glasswolf
NorthWest, Michigan
Post Number: 5217
looks nice.
could flush mount all the amps and such. that'd look nice, too.
Username: Rsoares28
Post Number: 20
thanks glasswolf, what do u mean by flush mount the amps
Username: Glasswolf
NorthWest, Michigan
Post Number: 5271
like this:
http://www.wickedcases.com/caraudio/nakamichi-RF_01b.jpg
Username: Sancho886
El Cajon, CA
US
Post Number: 28
would the amps run any hotter mounted like that?
Username: Glasswolf
NorthWest, Michigan
Post Number: 5291
not really, unless you mount them under plexiglass or lexan. at most, you can just add a couple of 80mm computer case fans.. push/pull style to force air through the shroud under the top board.
flush mounting is pretty easy.
use plywood, mark out the openings and cut them, cover the board in vinyl or carpet, then add some stand off legs at the right height.
That's about all ya need to do.
you can shim the components so they all sit at the same height before ya start.
It adds a really nice look, and it makes the trunk more useable because you can toss stuff into the back and not worry about hitting wiring and stuff.
It's all hidden under the top board, which you can easily lift off to get access if needed.
Home > Message Board > Car Audio > Amplifiers > Archive through November 04, 2004 > My setup [ « Previous ] [ Next » ]
