Thread: Car stereo in my room |
Unregistered guest |
| Posted on Monday, October 25, 2004 - 07:26 pm: |
Is there some way that I can convert the car cd and tuner into 12v or whatever comes out of the wall so that I can plug it in in my room?? |
Silver Member Username: Erik123456
Arlington,
Tx
Post Number: 182 Registered: Aug-04
| Posted on Monday, October 25, 2004 - 09:12 pm: |
you have to get a flux capacitor first try ebay |
NorthWest,
Michigan
Post Number: 5155 Registered: Dec-03
| Posted on Monday, October 25, 2004 - 09:14 pm: |
you can, but it's cheaper and will sound better to just buy a home theater in a box setup
Arlington,
Tx
Post Number: 183 Registered: Aug-04
| Posted on Monday, October 25, 2004 - 09:17 pm: |
glass didnt like my back to the future joke lol hey glass i posted this in the subs section when you were talking about cdt but are the CL 61A components for 150 a good deal? http://www.woofersetc.com/product.asp?0=239&1=240&3=3281 and why are they so much cheaper than the CL 61's? |
Arlington,
Tx
Post Number: 184 Registered: Aug-04
| Posted on Monday, October 25, 2004 - 09:19 pm: |
i guess my question is how do the A's compare to just the 61's and the 6.1 perfects and XR's that Johnathan had me checking out because for 50-80 bucks cheaper than the aforementioned components the A's are sounding like a good deal |
Arlington,
Tx
Post Number: 185 Registered: Aug-04
| Posted on Monday, October 25, 2004 - 09:31 pm: |
interestingly enough if you look up flux capacitors on ebay someone claims to have made one which "By creating a specific ,quite loud frequency of sound, it is supposed to warp time on a small area oscillating between past and future. " |
| Posted on Monday, October 25, 2004 - 09:46 pm: |
thanks |
NorthWest,
Michigan
Post Number: 5168 Registered: Dec-03
| Posted on Tuesday, October 26, 2004 - 09:20 am: |
the CL61 set is different. different crossover and tweeter etc.. the CL61A is a model down from them but much cheaper and still a very good set of speakers for 150
