Thread: simple wiring question for alpine cda9827 |
fargloe Unregistered guest |
| Posted on Monday, October 25, 2004 - 05:34 pm: |
Ok i have bought an Alpine cda 9827 and i am installing it in a maxima 91. In the instructions od the alpine it says to use a supplied screw to connecnt the ground to the chasis.....but there is a wire for the ground on the harness i bought. Also. on the old (but aftermaket) tapeplayer, the ground from the hraness is not used and the tapeplayer gorund wire goes to the cigarette lighter....i didnt know that the lighter could be used as a ground but anyway i want to know if i should cut the wire going to the lighter and use it or use the harness's ground wire or should i put the ground sumwhere else. I would also like to know where the usual spots for grounds are located. And i am a little confused what the blue and blue\white wires are used for. i dont know if there required to be connected, what they are used for, or if they are for separate amps.
fargole Unregistered guest |
| Posted on Monday, October 25, 2004 - 05:50 pm: |
i also know that the blue is for pwr anntene and blue\white is for remote amp turn on |
NorthWest,
Michigan
Post Number: 5146 Registered: Dec-03
| Posted on Monday, October 25, 2004 - 06:25 pm: |
only need pwr ant if ya have a power antenna only need remote if ya use amplifiers connect ground to a good metal ground point. where that is shouldn't matter. the factory harness ground should work unless it causes noise in the system.
