Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2004 > Nissan Titan Amp installation
Author Thread: Nissan Titan Amp installation
Username: Badgercor
I am trying to hook up my amp but I need to splice into the factory wiring but I can't find an wiring diagram to see what wires to tap into
Username: Glasswolf
NorthWest, Michigan
Post Number: 5127
factory head unit?
what exactly are you trying to find?
power goes to the battery
ground goes to bare chassis metal
if the head unit is aftermarket, RCA lines go to the radio's pre-outs, and remote trigger goes to REM or PWR ANT on the radio
Username: Badgercor
I have the factory (non-fosgate) system, and I am trying to add my MTX amp by using the speaker level type inputs since the factory deck doesn't have RCA outputs, and I cannot find awiring diagram for my truck to know which wires to tap into, I have the loom that goes to the back of the truck open but there is at least 6 different pairs of wires in it on the passenger side. And on the other side there is about 4 wires on the drivers side. Any help would be great
Username: Glasswolf
NorthWest, Michigan
Post Number: 5164
just remove the rear speakers and tap into the wiring there.
Username: Badgercor
That was going to be my last resort since I have to pop the whole door panel off to get to it.
Username: Glasswolf
NorthWest, Michigan
Post Number: 5194
takes 5 minutes to pull a door panel. ten tops if everything is electric.
it's no big deal really.
besides, it helps ya learn more about your truck!
Username: Badgercor
Thanks for the help
Username: Pat_l
Tucson, AZ
Post Number: 695
nice truck!
Username: Devro1835
jeff,
were you able to figure out the colors of the rear speaker wires
i've got a titan and need to do the same thing u are doing.
Thanks
Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2004 > Nissan Titan Amp installation [ « Previous ] [ Next » ]
