Home > Message Board > Car Audio > Amplifiers > Archive through October 27, 2004 > QUESTION FOR GLASSWOLF!!!
Author Thread: QUESTION FOR GLASSWOLF!!!
NeedMassiveHelp
Ok...I have 2 12" Solobarics and a KX1200.1, now at first I had the crossover on tghe amp at 50hz and my pioneer 7600mp HU at 40hz in "Super Bass" Mode...Now I heard that this is kinda too low for subs and could bottom them out and possibly blow them and also I dont like how its not catching te higher low notes...so do you have any opinions on how many hertz i should put the crossover and the HU...Im looking for massive bass and its for rap music...Thanks for any help!
Username: Glasswolf
NorthWest, Michigan
Post Number: 5116
set the bass EQ on the head unit to peak at about 40Hz, that's good.
set the LPF XO on the amp for about 80Hz and try that.
you can work your way down from there till you like the feel of it.
Home > Message Board > Car Audio > Amplifiers > Archive through October 27, 2004 > QUESTION FOR GLASSWOLF!!! [ « Previous ] [ Next » ]
