Thread: Where to find 4"x6" 8 ohm speakers |
| Posted on Monday, October 25, 2004 - 10:17 am: |
8 ohm is OEM for a piece of equipment of mine. Are they available anywhere? All I can find is 4 ohm. I'd like to keep it original without going the autoformer route. Thanks. |
NorthWest,
Michigan
Post Number: 5120 Registered: Dec-03
| Posted on Monday, October 25, 2004 - 01:23 pm: |
won't have much luck there. unless you go with a factory replacement speaker from a dealer.
| Posted on Monday, October 25, 2004 - 02:27 pm: |
This was the premium sound system in Allis Chalmers combines in the early '70s'. OEM hasn't been available for a LONG time (I can see why). Thanks for the reply. |
NorthWest,
Michigan
Post Number: 5130 Registered: Dec-03
| Posted on Monday, October 25, 2004 - 04:55 pm: |
some GM factory speakers are 10 ohms. That'll be a fairly close match. You could probably try using LPads to attenuate the signal to a set of 4 ohm 4x6 plates as well, which may work out for you since an Lpad circuit adds impedance to the circuit path. http://www.bcae1.com/lpad.htm
| Posted on Wednesday, October 27, 2004 - 08:40 am: |
The Lpad concept is new to me, but looks like it may be the way to go. That website does a nice job of explaining/discussing it. Thanks! |
