Thread: What is the Best Amp for Infinity Subwoofers? |
New member Username: Eejay
Post Number: 2 Registered: Oct-04
| Posted on Sunday, October 24, 2004 - 09:35 pm: |
Would anyone know what type of amp would be best for a single 12" Infinity subwoofer in a sealed or vented enclosure? The peak power is 1230 watts and 300 is the RMS wattage. |
New member Username: Dustin_9
Greenbrier,
Arkansas
Post Number: 6 Registered: Oct-04
| Posted on Sunday, October 24, 2004 - 09:47 pm: |
Personally i cant afford JBL amps so I would go for the RF p3002 amp puts out 300 w rms if you just bridge it to the one sub and it is definatly a quality amp for about half as much as you would need for a JBL BPX1100.1 |
Silver Member Username: Boopers
Lima,
Ohio
United states
Post Number: 213 Registered: Jul-04
| Posted on Sunday, October 24, 2004 - 10:09 pm: |
what about the jbl bp1200.1z on cardomain or whatever for like 200? or even the jbl bp600.1z for less? |
Gold Member Username: Jonathan_f
GA
Post Number: 2497 Registered: May-04
| Posted on Monday, October 25, 2004 - 12:30 am: |
JBL 600.1 is perfect for those subs. |
