Thread: Will my amp power these subs? |
New member Username: Dustin_9
Greenbrier,
Arkansas
Post Number: 5 Registered: Oct-04
| Posted on Sunday, October 24, 2004 - 09:26 pm: |
I just purchased two brand new Rockford Fosgate P210s4's (punch 2's not 1's ten inch). I have a RF p2002 amp. I dont know if my amp will be enough to power those two p2's so if glasswolf or someone can tell me if i will be alright as far as power goes. Thanks in advance. |
New member Username: Bumpingloud
Phoenix,
AZ
Post Number: 3 Registered: Oct-04
| Posted on Monday, October 25, 2004 - 10:21 am: |
How Many Watts Rms are they? And What's your amps specs. |
Greenbrier,
Arkansas
Post Number: 8 Registered: Oct-04
| Posted on Monday, October 25, 2004 - 07:03 pm: |
the subs are 200 w rms and 400 w peak power and my amp is a RF p2002 but im not sure exactly how much rms watts to each channel im running, and doesnt ohms have something to do with how much each subs gets? |
NorthWest,
Michigan
Post Number: 5152 Registered: Dec-03
| Posted on Monday, October 25, 2004 - 09:03 pm: |
Rockford Fosgate Punch P2002 MSRP $190.00 US Channels 2 Per channel power CEA-2006 compliant 50 W x 2 @ 4 Ohms RMS 100 W x 2 @ 2 Ohms RMS 200 W x 1 @ 4 Ohms Bridged RMS Total power 200 Watts Bridgeable Yes Crossover HP 40-400Hz 12dB per Octave LP 40-400Hz 12dB per Octave Tone controls Bass Control 0 to 18 dB @ 45 Hz Signal input Low level - Quantity - 1 Type - RCA(pr) Line output 1 RCA(pr) Phase control Power input Connector - Block Wire gauge - 4 Speaker output Block Power supply topology Output topology Display Heatsink Type -Cast Protection Remote control Included Type - Wired Controls - Bass Class A/B Marine use Specifications Stereo/Mix mono Frequency response 20 to 20k Hz +/- .5 dB Dimensions 2.4 X 11 X 11.7 (inches) even at 2 ohms, you'll only get 199w x 2. that's not really enough power. how many coils and ohms per coil for each sub?
Greenbrier,
Arkansas
Post Number: 9 Registered: Oct-04
| Posted on Monday, October 25, 2004 - 09:07 pm: |
I cant tell you. I dont have the subs here i put them on lay away until i sell my other subs. I just need to know if i have to have a new amp to run these subs. |
NorthWest,
Michigan
Post Number: 5159 Registered: Dec-03
| Posted on Monday, October 25, 2004 - 09:27 pm: |
yes. you'll need a different amp. which amp will depend on the subs
