Kenwood kvt 815 dvd player default security unlock code
Username: Icecort
Carson, CA United States
I bought a cd player from a friend, but he couldn't remember his unlock code. Is there a universal unlock code for these dvd players?
KCAR universal unlock
Username: Erobertst
I bought a head unit from a friend but he forgot the security code is there a way to unlock it
djmt
how can the KCAR be the universal code if you can only enter numbers from 0 to 9 ???
Username: Stonedkik
i assume KCAR stands for 5227 (according to the number on a phone's keypad)
Username: Harry_f
British Colu... Canada
I have tried to use this codefor a kenwood car deck i have. The model # is KDC- MPV6022. This code didn`t work for this radio. Does anyone else knowof a code thjat will work for this model ? And also after I enter the code, ISthere something else I should push to have this code intered ?
Username: Harry_f
I have tried to use this code for a kenwood car deck I have. The model # is KDC- MPV6022. This code didn`t work for this radio. Does anyone else know of a code that will work for this model ? And also after I enter the code, Is there something else I should push to have this code entered ?
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that "..." disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key "5" ( 2 times ) and press the Track UP/Next Track key
* Press numeric key "2" ( 3 times ) and press the Track UP/Next Track key
* Press numeric key "2" ( 1 time ) and press the Track UP/Next Track key
* Press numeric key "7" ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Username: Manu
i have bought a ken wood car cd player model kcd 6021y made in malasia from my friend .he has given me the unlock code but i have misplaced it and i dont remember the code now. now how can i open the security code with out that code.
sounds like you stole it and need the unlock code you lying foreign theif.
White Girl
That wasn't cool!!!
Username: Carguy
Post Number: 3713
No need to be rude. We're all here to help.
Manish Arora, you will need the code to unlock it. If your contact is still good, get it.
You can also try contacting Kenwood for support. They might help you out.
Thank you.... IT REALLY WORKS...
for anyone, when finish all the procedure, is necessary to press "TRACK UP BUTTON" for 3 seconds.. and youre done.
Username: Diablojoe
I am glad there is someone here who really knows what they are doing.
I have a problem with a car that the dealership that I run had traded in.
It has a KVT M70 unit in the dash, but it does not fit into any of the three categories that are described above.
Does anyone know how to get the dashes to disappear from this unit? it is a touch screen model without any cd or dvd in the unit.
I would hate to have to purchase a factory unit for this car and still have a locked in-dash tv that is worthless to us.
Username: Diablojoe
let me just fix my typoes here. it is a KVT M700
ok well my dad had gotten this car off a used lot and it had a kenwood cd player in it and then he got into an accident and so im tryin to use it but he never got a remote with the car and i not sure what to do. its a good radio i dont wanna let it go unused
man with plan
Ok you guys I just had a problem with a kvt715 being locked and I paid a site 40 dollars for this info,It does work the code is KCAR BUT its how you use the code whether it works or not the first thing you have to do is have a remote-Will not work without remote,....Turn on unit and the screen will come up for password..using remote press 5 two times,wait 2 seconds and press enter,NOT track up press 2 three times wait 2 seconds press enter,press 2 One time wait 2 seconds then enter and finally press 7 two times and press enter! your screen will be unlocked if you did it right,If you have to try again turn off and then back on.AGAIN the site I paid for this at says push track up but that did not work for me,Goodluck THIS WILLNOT WORK ON 911 unit.
kyrstan
can any remote work or does it have to be for the same make and model? bc we never got a remote when we bought the car from the auction
man with plan
the remote needs to be the correct remote for the unit,If you need a remote you can probally purchase one at http://www.pacparts.com goodluck.
sambolina
Hi
I have come across 2 lcd screens (from ford windstar mini van dvd) that I would like to add to my dvd player in my truck. The lcd plug is a 6 pin plug. The name brand on the lcd is autovision. The pin has 5 wires.
Black
Red
Green
Blue
Gray (clear)
I tried to hook up the red to power and black to ground and green to a RCA jack plug, but I get nothing on the lcd screens. Help. I wanted to make it with an rca video output to hook it up to my dvd player. Does anyone know how to get these things to work?
post or email me with any info at samtinie@yahoo.com
Thanks
Sam
Username: Chrisaber
Covington, Ga Us
unlock code for kvt911dvd and how to do it
kyrstan
so i bought this remote and i still cant unlock it its a car cd player kenwood kdc-515s if anyone can help please i have had to drive around for the past week with no radio or music at all and it stinks.
kyrstan
and i paid for a remote but it has no numbers on it did they send me the wrong one?
kyrstan
Username: Chrisaber
Covington, Ga Us
does anyone know the code to unlock kenwood kvt911 dvd i bought a car at an auction and the receiver is locked
Mobilio
I've had this Kenwood deck model # KDC-X811 for many years and never had the need to lock it but just recently my battery in my van whent dead now the deck is locked how can I unlock it?
KENWOOD11203
THE WHOLE POINT OF THE CODE IS TO DISCOURAGE PEOPLE FROM STEALING IT, NOW YOU GO AND TELL THEM THAT THEY DON"T NEED THE CODE TO USE THE DECK----GREAT THINKING RETARD----IF YOU LOSE YOUR CODE< CONTACT KENWOOD,
Krugger
The last post is somehow right, but...(there is always a: "but"
My dear friend (Kenwood11203?!)i'm a service tech and sometimes people buy the car with the radio on it an need to be serviced or really lost the code, and tellme if you keep all the receipts for the stuff you bought in the last three years please!
And remember that most of the robbers out there don't have the mediums-skill-whatever to find this info.
Also ifthey are trying to input the code is because your window is already broken. :-)
Relax and enjoy life buddy!
Kenwood ddx7017 christian
KENWOOD DDX-7017.......i may buy this system from america which is alot less than in the uk. however it will be a region 1 and want region 2.....yes i could copy every dvd i ever want to watch however, far too much hassle so.....any1 know any fancy shiz to convince me to buy it?????
Peugeot 406 lx phillips stereo - code required after car was broken-into?
disurbed burgalar, who ran away. Reported crime, but police were unable to catch/locate/help.(crime ref:20d317396-04)-
Police suggested try your forum for code(subsequently required):
Phillips stereo model:22DC594/65
Recently our car was broken into & the stereo was attempted to be removed, but Product no:FD0297299/35457
E9723 M/Ch 136555 9022 2159465/9
Ref:Peugeot 96169788ZL01
PLEASE HELP F.0.C.?
Email 4-digit Code to: 2000midlands@mail.ru
Thanks
jiggityjay
I'm in the same boat as everyone else. I have Kenwood KDC-PS809 in a new to me, used car. Needs the security code because the faceplate is locked. Problem is i can't even figure out how to enter the code. The face plate just says "Code Off" then proceeds to operate, of course without the functions of the faceplate buttons. How do I get to a point where it will ask me for the code? I tried each of the three methods mentioned in a previous post but they all seem to imply that the faceplate is already asking for the code, which mine is not. I would appreciate it so much if someone could help. Thanks!
HI I HAVE A KCD-5016 HEAD UNIT AND IT HAS COME UP WITH ( WAITING 2 ) ON THE SCREEN DONT KNOW HOW IT HAPPENED BUT MY SON WAS PLAYING IN THE CAR AND WHEN I GOT IN IT THAT CAME UP WAT DO I DO AND HAVE NO REMOTE THANKS TO HIM AS WELL
I BOUGHT A KVT-911-DVD ON EBAY ....WHEN I BOUGHT IT I DIDNT THINK IT WAS GOING TO BE LOCKED SO NOW I AM HAVING A HARD TIME GETTING IT UNLOCKED.....IS THERE ANYONE OUT THERE THAT CAN HELP ME UNLOCK IT OR THAT HAS A CODE I COULD USE ?
THANK YOU IN ADVANCE .....
AROeK
i bought a kenwood kdc mvp5025 from a friend he told me the code he "remembered" but it didnt work he lost his ownwers manual so now we cant find the code to unlock it
can any one help me wid this?
Username: Bishop_150
Hey people, names Chad. I have a huge prob. I purchased a new Kenwood KDC-MP7028 back in April. I had it professionaly installed and everything, I had to play with everything on it. I got to the security code part, and of course activated it. I never dreamed I would have to use it again, so like a idiot I didn't write it down. Well I recentley done some mods on my truck and had the battery out. Wouldn't ya know, I DON'T HAVE THE CODE. Kenwood says I'll have to send it off, that will take months I know. There has to be a way to reset this code yourself, please help me, I NEED TUNES. KDC-MP7028
Hi.. I have a Kenwood Kvt 815 in dash dvd.. yadda yadda... everything is hooked up, but when i put in my dvd it plays the sound but doesnt show no video??? the screen comes out and shows me the options to play, stop skip so on.. and i dont have a remote, i lost it when i was moving into my new apartment.. my boyfriend just hooked it up.. and now its not acting right... what do i do??
Confused...
Thanks for any help
This site is interesting...I don't have a Kenwood but could use some infomation on an ECLIPSE ESN High Powered cd reciever #5331 Same here has taken the battery out 2-3 times last Sunday had to take the battery holder out to remove the resovoir to the radiator.(flushing)Never had a CODE...I've had the car for 6 yrs never this if ANYONE could help i'd APPRECIATE IT... THANKS
By the way on that ECLIPSE 5331 it only go 1-6 HELP LOL THANKS ANYWAY
HAPPY TO GET
I found HELP from H Akins PO Box 3025 Chattanooga Tn. 37404 Also Jay Jaz15@aol.com I have a CD PLAYER "HI POWERED" was in the HELP mode..could'nt get the "CODE".Player COST TOO MUCH to TRASH. The radio shops that i went to wanted to replace it $600-$900 I'm glad that i got the IMFOMATION that i needed.( It was well worth me taking it out.)For the small amount that i spent vs REPLACEMENT i feel GOOD It might be worth it if you got a decent player or like this player and don't wanna SPEND all that MONEY again. PASS THIS INFO ON!!! MUSIC BACK LOL
Holding down the ATT and 4 buttons and reseting the headunit should give you 30 minutes to listen to your music. After this it needs to be reset. I have to do this as my KDC-MV6521 is on code ---- 1 and i am unable to unlock it!!!!!!!!!
Any help?????? P.S tried holding down Auto & Track up buttons and also tried volume up & DISP. Also have remote RC-420
i have akvt-911 dvd and its locked out....
can any help. all the car audio places and even
kenwood wont fix it with out a recipt. i bought it off e-bay about 1 year or so ago.
Needed HELP!!!
I FEEL A-OK GOT "HELP" FROM JayJaz15@aol.com
Needed HELP!!!
I buy a Kdc-8015 radio/cd unit from e friend
but he forget to give me the code
Rudy Clavel
please help - I bought my Mitsubishi Challenger car (also called montero in the states) 3 years ago and it has a kenwood KDC 5016 installed. i changed my battery today but when i try to listen to my car stereo, it was asking me to enter a code. After reading the manual,i tried some combinations but after the 3rd time, i had to wait for 24 hours for me to be able to enter another set of codes. found the service document and rang the previous owner but he doesn't have any idea and was quite rude too. I know this is a long shot but is there a default code that i could try in case the previous owner used that code? i also noticed a clearing of the code option on some of the models. I could try them but if someone could help. it would be much appreciated. I tried to convinced wifey to upgrade but all i got was a stiff NO answer.. please help .. thank you
hello, i've purshase a kenwood kdc-9020r on e-bay(look's the same as a kdc-mp919), but the problem is that in the screen it says == waiting 3 == can anyone help me to get it unlocked??... i've seen the way to unlock it, but i cant get the waiting 3 off... thank's
Helper1
I have a 6090R. These type of Kenwood head units have no "backdoor" code or workaround. There is a 24C01 EEPROM (128 byte) in the player that needs to be read. Connection can be made with specialist kit. I use these EEPROMs at work and have interfaced to them on many occasions (SPI device).
I'm afraid you need to go to a specialist to get it decoded.
Hope this clears things up for some of the people posting here.
helper1
I have found a method that does not need a dump of the EEPROM. You have to be able to strip the CD/tape block out of the unit and power it up (preferably on a bench). If anyone is interested and happy with the above, the rest is simple!
I know this is an old forum post. If anyone replies I am willing to help
Username: Sp1086
Gold Coast, QLD Australia
Hi I have a Kenwood KVT940DVD which I purchased from eBay and it has the security code enabled.
The person I purchased it from cant remember the PIN number as you enter your own number when enabling the security feature.
Can anybody tell me if there is a default code that can be entered to get around this problem.
Thanks.Upload
Username: Jimmah2007
i got a KDC-MP7028 Car Sterio for christmas and i blew my fuse so i changed it and now its asking for a code that i dint remember is there a universial code to over ride that if u could help me it would be greatly appreciated u can e-mail me at j.mikes19@sbcglobal.net thank u
Username: Bighoe51
Last week I bought the Kenwood KVT-910 DVD, a Performance Techniques 500w amp, and a 10" Kicker CVR sub, with brain, harness, pretty much all required wires from a guy's ad in the recycler for $600. Not a bad deal, I guess.. It came out of his 2005 350Z, so it was a good set up for me.
Here is my dilemma,
I just had it installed at my local stereo shop last night to find out when I turn the DVD player on it asks me for an unlock code.
I have owned Kenwood HU's before and totally forgot I would need an unlock code for this unit. I called the person who sold it to me and he told me he didn't get that code prompt when he put it in his Z (which is BS since this happens every time you disconnect it from power). So he says he will try and call the stereo shop he got it installed at, Kenwood, and even Circuit City where he originally purchased it 3-5 years ago, whenever this unit first came out.
I am yet to hear back from him today, but after being so pissed off last night searching vigorously through the internet for some sort of resolution, I've come up with SOME help (KCAR method, other reset methods), but still no go. <IMG SRC="https://www.ecoustics.com/bbs/clipart/sad.gif" ALT=":-(" BORDER=0>
My question to you guys: Does anyone own a similar head unit, or know of anyway to bypass this from experience? I have a bad feeling that this guy will either; 1) Never get back to me, or 2) Tell me he cannot get the code. In which case I will try everything I can to get my money back, and bite the $160 installation cost.
I understand anyone who reads this can assume that I stole this unit and am trying to find an easy way to get into it. Well, assume that. That's definitely not the case.
I'm really just looking for some help/advise here, please no smart comments, you must take this situation in perspective first. I spent this money to see it sitting in my car and not working, imagine how I must feel.
Thanks for your time guys. I really appreciate it.
Username: Sp1086
Sorry to tell you that there isn't any way around it apart from getting the code from the guy. Or if you can get the original purchase reciept Kenwood can help you. Sorry for the bad news.
Username: Charlied87
actually im in houston texas and i had the same problem but i bought the unit off ebay and when i turned it on, it had the same problem. there is a guy that charged me 120$ to unlock this code. he changed a few micro chips out and now my unit is working fine.
Username: Idamasena
Unfortunately i have a similar problem to many of those posted above. My girfriends car battery went dead, by replacing it we reset the Kenwood cd player....we have no idea how to even begin entering the code...which ofcourse was lost a long time ago. The model is KCD9012R....when it turns on it comes up with [ 1 ] thats it. Does anyone have any idea how to 1st of all begin entering the code and 2ndly what the default code is??
Any help would be much appreciated.
Username: Havoksgurlie
So my kvt 911 got stolen last year. And I am installing my new one but because i have to park on the street i wanna be able to take it in and out. How do i remove the plug on the back that is a rectangular plug that has a plastic cap? Any ideas none of my firends can figure it out.
thx so much
Username: Momorps
I have a KVT-715 and it stopped producing sound. It was working fine on my way to work but on my way home I turn the system on and oddly enough it asked for the code. Somehow it reset by itself and after I got the system up and running again I see the song timer running but no sound. No matter what I play - AM/FM, CD Changer, MP3... nothing. I checked the audio settings, unplugged the receive, and even disconected the battery to reset again but no luck. Please help.
Username: Dan_the_best
Hi there
my car cd player is frozen with the message saying "waiting" on it. it is Kenwood KDC-8060R. I know the code but it is frozen and won't let me to enter any number.was wondering if you can help me out with that.
Regards
Hamed
Username: Chekaho
Does anyone here have the installation manual to the kvt-910 or 911 if so please send it to chekaho@hotmail.com. Thank you before hand.
Username: Jet
ok so i have the kcar code but i cant get through the 4 dashes. i have a kvt-m700 and the remot but the procedures given above i cant do because i dont have an "auto"button on the faceor the "DISP" key. any help would be greatly appreciated, thank you
Username: Rulzz
I have a KDC- MPV6022 and I used code 1234 than pressed >> button for 3-4 seconds and viola. Maybe,it will work for others too. }
Username: Aoesab
Hi,I need some help with my Kenwood KVT-715DVD i bought it like a year ago,my radio has been working fine for this whole time but 3 days ago my car run out of batterie and when I fix it, the radio was locked. I never input any anti theft code so it is not asking me for a unlock code at all, the problem is that all the buttons, but the one to take the monitor in and out, are not working, the remote isnt working neither.The only button that works is working just once each time i turn the radio on. Also if i input a CD it will play it, but i cant turn the volume up or downor anything because the buttons at the touchscreen are not working. I know it get lock but i cant unlock it becuase i never setup an anti theft code, but there should be some butons i should press at a time or some secuence to unlock it, anyone know how to fix it?
Username: Nartina
hi everyone, i have a Kenwood KDC-5023 4 years ago and i had the car audio paasport in my wallet till i had thiefs came into my house and stole the wallet my wifes bag and her jewellery anyway i sold my old car and bought a new one and installed my KDC-5023 and it asked me about the code so now i`m trying to see if there is any unlock codes coz i don`t have mine,i need to give it another chance before i give up and buy a new one,,i tried the code KCAR but it did not work nothing came on the screen when entering the code KCAR.any good help is much appreciated could you please send it to my email ranart_love@yahoo.com.au
Username: Puertoricanlace
Bakersfield, Ca U.S
Can U Help Me ?....I Need The Code To My Kenwood KDC-MP628 E-Mail Me At Puertoricanlace@aol.com
Username: Lucastro97
bought a kenwood kvt-910dvd player comes with a rc-dv100 remote ,anyone knows if the 2 go together,paid 40 bucks for code but cant unlock.press the power button & item powers on but screen stays in,is thet what it does when locked?code sent to me was 5227 dvd player plays cds,throught the brain that came with it but no screen can also hear the movie playing when all compoinents sre connected.help
Username: Ibn80
Pleeeeeease I need Help, I just bought a truck and it had a kenwood ddx-6019 installed, which was great. I upgraded the sound system and changed the battery under the hood and now I can't get into my radio because the darn thing locked on me. I have been without a radio for 3 weeks and it is killing me. The audio shop couldn't do anything and I don't want to buy another radio I want the tv feature. If there is anyone out there that can help me pleeeeeease put music back into my life. Thanks in advance
Username: Bichosoul
Hello, I'm from Panama and bought a second hand Nissan Patrol about 2 months ago. It came with a Kenwood DDX-7047.
This weekend I took out the battery from my car to start another and when I started my car again, the DVD was on "Pass Word". The previous owner claims that he didn't set a password, I didn't set a password... now I'm damned.
I have tried many (if not all) of the tips posted here, but nothing happens... now I'm trying up the codes one by one.
I just wanted to try, is there anything else I could do? Some of the tips posted use the remote, I have mine, but none of the keys are working.
I would appreciate any help you could bring me.
Mi email is enochguerra@yahoo.com
Regards.
Username: Jetta1120
Vermont USA
Hey everyone.
I need some help. I was given an Eclipse deck and I dont have the security code for it, and was wondering if anyone knew how to reset the codes on Eclipse decks.
Please let me know if you know how to fix my problem
Thanks
rhaus1120@yahoo.com
Username: Bpoakes
Fayetteville, Nc Usa
hello everyone,
I am a diesel tech at a ford dealership in NC. A customer came in recently and tradein his veh for a newer one. He had a kvt 717 and we took the radio out the car and I installed it in my truck. Recently my batter went dead on my truck and the kenwood magazine I had written the code on was thrown away by my wife. I contacted kenwood and they told me that I would have to purchase a new radio, that there was nothing they could do to help and the phone number the dealership has for the person is disconnected. Does anyone have any ideas what I can do to get my system unlock or who I can call.
Username: Michrich11
Kamloops, British Colu... Canada
My husband has taken his DVD player out of his truck and put in my van. He can't remember the password or find the remote. Is there anyway to override this? IT is a Kenwood KVT-715
Username: Brucecarter1
Phila, Pa
hi i have a kvt-717 and i never istalled a security code i had this tv for to years and the batt i my van just croaked so i replaced it and like every one else it asked for the code doe,s any one no it cause the kenwood service station said they could send it to upperstate ny for $165i,m like dam thats alot please help
Username: Kerryn09
Launceston , Tasmania Australia
Hello,
I have recently purchased a Kenwwod KVT-940 off ebay that has a code on it. Is there a universal code that I could use?
Thanks kerryn
Username: Kerryn09
I do have proof of purchase as well..
Username: Sp1086
You need the original new purchase reciept (eBay reciept won't do) and the serial number of the unit. Give Kenwood a call and they should be able to help you. You may have to put it into them so they can reset it. As far as I know there is no default code on the newer units. I eventually got the code for mine from the guy I bought it from on eBay with alot of hassel mind you.
Username: Kerryn09
Thanks so much for your reply Chris E. I sat here last night with determination and a print out of all the possible combinations and I got it...Which is great.Thank you so much for your help.
Thanks again Kerryn
