Thread: Should I get this amp? |
Bronze Member Username: Xxkmfdmxx
Post Number: 11 Registered: Oct-04
| Posted on Saturday, October 23, 2004 - 08:42 pm: |
Friend of mine is selling a Sony Xplode XM-D400P5 800watt amp for $75, How is this amp? any reviews on it. It's gonna be hooked up to two 5x7 150watt speakers and two 350watt 5.25 |
Post Number: 13 Registered: Oct-04
| Posted on Saturday, October 23, 2004 - 09:42 pm: |
Or if someone could reccomend a amp for like under $100 |
NorthWest,
Michigan
Post Number: 5046 Registered: Dec-03
| Posted on Saturday, October 23, 2004 - 11:23 pm: |
sony amps are total crap. very high failure rates and very poor performance. no good amps are under $100. the JBL P80.4 is about the cheapest amp I know worth buying that'd do the job.
Post Number: 14 Registered: Oct-04
| Posted on Sunday, October 24, 2004 - 12:00 am: |
Not even no decent ones for under $100?, I have a Mobile authority 180watt amp laying around. should I just use that? |
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 691 Registered: Apr-04
| Posted on Sunday, October 24, 2004 - 12:53 am: |
no, no, no for the sony |
Post Number: 16 Registered: Oct-04
| Posted on Sunday, October 24, 2004 - 03:00 pm: |
What about a Clarion APA250? or a BAZOOKA EL260? |
Silver Member Username: Jeremyc
Kunsan Afb South Korea
Post Number: 145 Registered: Jun-04
| Posted on Sunday, October 24, 2004 - 04:41 pm: |
bazooka is a no / clarion is better but I am still not a big fan |
Post Number: 146 Registered: Jun-04
| Posted on Sunday, October 24, 2004 - 04:42 pm: |
Take glass's advice. Save up some more money, and get a better amp. |
Post Number: 17 Registered: Oct-04
| Posted on Sunday, October 24, 2004 - 05:43 pm: |
ok well, by the end of this week I should have $180 to spend on one, Would the JBL glass reccomened be best for under 180? |
NorthWest,
Michigan
Post Number: 5089 Registered: Dec-03
| Posted on Sunday, October 24, 2004 - 07:29 pm: |
now that's a much better budget to work with. you're getting closer to some decent amps. look at JBL, see what fits your needs. for 5x7 and 5.25" speakers though, you'd only ned about 40wRMS x 4 @ 4 ohms. that'll be a small, and relatively inexpensive amp to find.
Post Number: 18 Registered: Oct-04
| Posted on Sunday, October 24, 2004 - 08:13 pm: |
I saw a JBL LC-A304 for $40 on eBay, Should I consider this? If not then how about a JBL GTO301.1 or JBL GTS180X? Thanks for everyones help by the way. |
