Thread: Question? Anyone |
New member Username: Breaka
Post Number: 1 Registered: Oct-04
| Posted on Saturday, October 23, 2004 - 04:50 am: |
Does any one know why my +12 memory wire dosent work any more? i have a 97 Blazer, it was working then it just quit, is there anyway to fix this, also could i run a wire from somewere that would keep settings the same after i shut the truck off? thanks |
NorthWest,
Michigan
Post Number: 5033 Registered: Dec-03
| Posted on Saturday, October 23, 2004 - 03:06 pm: |
replace the fuse
Post Number: 2 Registered: Oct-04
| Posted on Saturday, October 23, 2004 - 09:45 pm: |
haha! Thanks GlassWolf I thought I looked through all the fuses but I guess not, now I feel like an idiot |
NorthWest,
Michigan
Post Number: 5055 Registered: Dec-03
| Posted on Saturday, October 23, 2004 - 11:55 pm: |
usually two. one at the fusebox, and one behind the radio a few inches from the unit on the wiring harness in-line. gotta check both.
