Thread: Question about hooking up two amplifiers |
| Posted on Friday, October 22, 2004 - 07:06 pm: |
I have my 4 channel amp already installed, and I have it all ran using the RF dual amp kit, do I just connect the second set of rca's to the line in on the mono amp i'm planning? or do i run another set from the subwoofer out on the hu... i would think running it to the other amp would be fine as long as the settings are correct on the amp, no? if you know of a site w/an tutorial / explanation of this it would be appreciated... thanks a ton. |
NorthWest,
Michigan
Post Number: 5026 Registered: Dec-03
| Posted on Friday, October 22, 2004 - 07:17 pm: |
run a set of RCA lines from the sub outs of the stereo to the amp. then you can use sub controls from the head
Eric Smithson Unregistered guest |
| Posted on Saturday, October 23, 2004 - 12:33 am: |
I have a 400 watt 2 channel amp and one 12" mtx sub that takes 600 max. I was wondering how i could get the amp to push the full 400 to my sub. i didnt kno if i could bridge or not...im new with this stuff.. |
