Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Adding relay for dome light
Author Thread: Adding relay for dome light
Username: 70el_co
Fort walton beach, Florida
U.s.a
i have an older el camino with a "vision" alarm sys. actuators were added for the door lock. im trying to add a relay to activated my dome light for however long the momentary 12v output is for, whenever the alarm is deactivated and the doors unlock. can any one help me. played and researched for a while, pretty frustrated.
Username: 70el_co
U.s.a
Username: Ps1k0
Post Number: 30
does your alarm have a domelight supervision wire?
70_el_co
what do u mean a "supervision wire" ?
Username: Ps1k0
Post Number: 37
a wire that turns on the dome lights when then alarm is deactivated.
whoever installed the alarm may not have used it. some shops don't so they can get it in faster. and some charge to do that.
Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Adding relay for dome light [ « Previous ] [ Next » ]
