Home > Message Board > Car Audio > Amplifiers > Archive through October 27, 2004 > Quick question!?!?!?!?!?!?
Author Thread: Quick question!?!?!?!?!?!?
Username: Ctx
Post Number: 80
im using a legacy amp for treble on my 6x9's and when i hooked it up barley any sound was coming out ive tried it on 6 diffent speakers,and turned up the level with the same results last time i hooked it up the treble was unbareably loud what did i do wrong this time>?
Username: Pat_l
Tucson, AZ
Post Number: 684
Try adjusting the gain on the amp
Username: Ctx
Post Number: 81
nope no prob with the gain
Username: Ctx
Post Number: 82
any other suggestions?
Username: Glasswolf
NorthWest, Michigan
Post Number: 5001
cheap amp. probably failed.
double check your wiring.. particularly your ground.
Home > Message Board > Car Audio > Amplifiers > Archive through October 27, 2004 > Quick question!?!?!?!?!?!? [ « Previous ] [ Next » ]
