Thread: Glasswolf? Jonathan?Help |
Steven Grader Unregistered guest |
| Posted on Thursday, October 21, 2004 - 07:01 pm: |
Is it possible to connect 1 SVC sub and 1 DVC sub to a Mono Amp with one input? Also I have a panasonic head unit i think somethings wrong with it, When i connect the av jacks to the back of it and play it it seems like the power is only going to the right channel of the amp cause when i unhook the right rca(red one) theres no sound going to the subwoofer from the left and as soon as i hook the right rca theres sound. but it dosent hit like it used to when it had the power to both rca inputs. Could i damage my subwoofer like that? It's not the amp cause i switched them and put another one and it was the same thing i also changed the Av Jacks and still the same. Can you help me please. |
| Posted on Friday, October 22, 2004 - 07:35 pm: |
anyone? |
Gold Member Username: Jonathan_f
GA
Post Number: 2476 Registered: May-04
| Posted on Saturday, October 23, 2004 - 01:22 am: |
It's possible as long as you don't exceed the amp's capabilities. It sounds like a head unit problem, no you won't damage the sub running it off of just one RCA, you'll just lose information from the left channel. |
| Posted on Saturday, October 23, 2004 - 02:25 am: |
That's what i thought it was because the side of the unit gets really hot like after 45 minutes of playing. and about the subs how would i wire them? |
GA
Post Number: 2485 Registered: May-04
| Posted on Saturday, October 23, 2004 - 02:52 am: |
What is the impedance of both subs, the SVC and the DVC? That'll determine how they need to be wired. |
| Posted on Saturday, October 23, 2004 - 09:21 am: |
The SVC 400rms and the dvc is 350rms |
GA
Post Number: 2489 Registered: May-04
| Posted on Saturday, October 23, 2004 - 02:40 pm: |
I need to know the impedance (how many ohms). Also, what kind of amp is it? |
| Posted on Saturday, October 23, 2004 - 03:00 pm: |
Dual 4 ohms and Svc 4 0hms I'ts an old school kenwood that i've had for over 4 years I think It's A 1993 amp. |
GA
Post Number: 2492 Registered: May-04
| Posted on Saturday, October 23, 2004 - 03:14 pm: |
It's probably 2 ohm stable if it's a mono amp. Only safe way to wire would be to wire the DVC sub in series, and both subs parallel to the amp. If you want the most power, I'd recommend using just the DVC sub and consider porting it for most output, you're straining that amp by running it above it's capabilities. |
| Posted on Saturday, October 23, 2004 - 04:36 pm: |
Are Ported Boxes better for deep low bass? I mostly listen to rap music with alot of bass. The kenwood amp is 2ohms stable. I know many people say kenwood sucks but do the old school stuff suck too. My amp has lasted a pretty long time. Thanks for your help |
| Posted on Saturday, October 23, 2004 - 04:38 pm: |
Can you recommend a store online with ported boxes. Sorry For double posting |
| Posted on Monday, October 25, 2004 - 12:28 pm: |
Where's everyone at? |
New member Username: Mali
Gebze,
Kocaeli
Turkey
Post Number: 1 Registered: Oct-04
| Posted on Monday, October 25, 2004 - 12:38 pm: |
ý wanna make a system up to 1500$... which brand is better for hittin' hard?
Gebze,
Kocaeli
Turkey
Post Number: 2 Registered: Oct-04
| Posted on Monday, October 25, 2004 - 12:40 pm: |
is there anyone here? |
NorthWest,
Michigan
Post Number: 5117 Registered: Dec-03
| Posted on Monday, October 25, 2004 - 01:16 pm: |
Mehmet, you'll probably get more help by starting a new thread to ask for help instead of posting in a thread someone else started to get help. at the bottom of the thread list page you'll see a "new thread" button. use that to post a new message. thanks
