Home > Message Board > Car Audio > Amplifiers > Archive through October 27, 2004 > GlassWolf...question about your advice
Author Thread: GlassWolf...question about your advice
Username: Philberg
Birmingham, AL
United States
I have heard you mention the JBL bp1200 amp a couple of times. you also said it was refurbished. do you approved of this refurbished amps on cardomain...thanks
Username: Jonathan_f
GA
Post Number: 2452
He's recommended that amp on cardomain, it's just fine. An amplifier that is refurbished is just as good as new, all the parts come on a circuit board, usually most companies just pull the board out and put another one in, then of course they verify it works correctly, etc. Just as good as the new ones are.
Username: Pat_l
Tucson, AZ
Post Number: 686
Yeah, alot of my system, HU and Subs are refurbished. Not had any problems. And sound the same as anyone elses.
Username: Southernrebel
Louisiana
Post Number: 240
Philberg,
i just purchaced two of those refurbished jbl bp1200.1 amps from cardomain.com. both work great. the only down side of these factory refurbished 1200.1's is that they have a few scratches.
other than the scratches, they are just fine. and these scratches arent even that bad.
Username: Philberg
Birmingham, AL
United States
Post Number: 8
thanks a lot, I'll look into it
Home > Message Board > Car Audio > Amplifiers > Archive through October 27, 2004 > GlassWolf...question about your advice [ « Previous ] [ Next » ]
