Home > Message Board > Car Audio > Amplifiers > Archive through October 27, 2004 > Amp output
Author Thread: Amp output
Username: Vybz05
I have a problem. I am going to buy a car <a href="http://www.serverlogic3.com/lm/rtl3.asp?si=11&k=audio%20system">audio system</a>. I'm going to get (2) Alpine SWS-1242d subwoofers. 300 watts RMS. They are DVC at 4 ohms each. I have read that if i wire them in parallel, i will end up with a 1 ohm load. Now, for the amplifier, the question is, if i buy an amp that puts out 600 watts RMS at 2 ohms, will it match the subwoofers even though they are at 1 ohm. Basically, can i feed 2ohms to 1ohm and still sound good?
Username: Johnnylemoine
LaPlace, Louisiana
United States
Post Number: 220
you would have to get a 1 ohm stable amp as to not fry an amp that is only 2 ohm stable.
Username: Vybz05
like the jbl bp600.1?
Home > Message Board > Car Audio > Amplifiers > Archive through October 27, 2004 > Amp output [ « Previous ] [ Next » ]
