Thread: I just bought a 1200watt Visonik amp for $400,its slightly used..good deal or no? |
New member Username: Dontknowwho11
Post Number: 1 Registered: Oct-04
| Posted on Wednesday, October 20, 2004 - 12:48 am: |
just wondering if i got ripped,also this price is in canadian. |
Gold Member Username: Jonathan_f
GA
Post Number: 2396 Registered: May-04
| Posted on Wednesday, October 20, 2004 - 01:29 am: |
$400 canadian? That's like $2 US, right ? Seriously, though, I think you could have found much better out there, not trying to make you feel bad, it's just the truth. I don't know what you plan to use it for, but if you can get your $$$ back you could do better. |
NorthWest,
Michigan
Post Number: 4925 Registered: Dec-03
| Posted on Wednesday, October 20, 2004 - 10:22 am: |
that's about $300 US give or take (too lazy to convert) for a 1200 watt amp. is it 1200wRMS @ 2 ohms? monoblock class D? the JBL bp1200.1 runs around the same price here in the US, new. $320. factory refurb, they sell for $200 on cardomain.com at best Visonik would be on par with the JBL. Those amplifiers aren't "top end" stuff, but if it works, and does what you need, hey being a good deal is totally your call.
