Thread: Slot port box building help |
Bronze Member Username: Thumprms
Dalton USA
Post Number: 40 Registered: May-04
| Posted on Tuesday, October 19, 2004 - 09:57 pm: |
could someone explain how to build a 2.0 cu ft slot port box? the specs for the port say 4 in wide and 10 3/4 in long. i'm having diificulty figuring out the demisions of the box and how wide the port should be because the specs are for a round port. |
Silver Member Username: Johnnylemoine
LaPlace,
Louisiana
United States
Post Number: 202 Registered: Aug-04
| Posted on Thursday, October 21, 2004 - 12:45 pm: |
Um, there is a place you can go to convert it, but if you can get the area of the 4in. diameter port, just make the slot port have the area,but square. Yu know? But, there could be other factors, Jonathan,FIshy ,or Glasswolf can help you with that.
