Home > Message Board > Car Audio > Amplifiers > Archive through October 27, 2004 > Which car amp??
Author Thread: Which car amp??
Username: Philberg
Birmingham, AL
United States
I have 2 1100W 12" dual subs in a box that I recently received. I need an amp but I dont have a clue what to look for because I dont understand anything...please help.
frequency response-25Hz-200Hz
Sensitivity-89dB
Impedance-4ohms
600W RMS
Username: Glasswolf
NorthWest, Michigan
Post Number: 4901
600wRMS at 4 ohms
www.cardomain.com
JBL BP1200.1
$200
that'll do the trick perfectly.
amp is on sale. usually about $320
Username: Thumprms
Dalton
Post Number: 39
what do you rate the JBL BP-600.1Z?
i found it on cardomain for $160. its factory renewed. do you recommend buying factory renewed amps?
Username: Philberg
Birmingham, AL
United States
thanks
any other advice about car audio would be appreciated
Vibe
I have bought the AC12T spaced loaded, its 1400 watts rms and 5600W peak, I've been told to run the monobox4 as it is a good match. Can anyone suggest any other amp that I should consider and would be good with this system.
Username: Glasswolf
NorthWest, Michigan
Post Number: 4921
they never listen, do they?
Vibe
Home > Message Board > Car Audio > Amplifiers > Archive through October 27, 2004 > Which car amp?? [ « Previous ] [ Next » ]
