Home > Message Board > Car Audio > Amplifiers > Archive through October 19, 2004 > 2JL12W7&JL1000/1 4 SALE
Author Thread: 2JL12W7&JL1000/1 4 SALE
Username: Doitbig22
Frankfort, Ky
Us
I HAVE A 2 JL 12W7 AND ONE JL 1000/1 CAPABLE OF 1000 WHATS NO MATTER WHAT OHM OR WHICH WAY U HOOK IT UP. I AM TRYIN TO SELL THE SUBS FOR 750 PLUS SHIPPING AND THE AMP FOR 525 PLUS SHIPPING OR BOTH FOR 1100 PLUS SHIPPING.
Username: Chevy_for_life
Post Number: 125
that amp is only rated at 1000 watts for 1.5-4 ohm.. so if you run it at 1 ohm u could Fu<k it up..
Rated Power: 1000 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
THD at Rated Power: <0.05% @ 4 ohm
S/N Ratio*: >95dB below rated power
Frequency Response: 5 Hz-500 Hz (+0, -1dB)
Damping Factor: >500 @ 4 ohm/50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions: 19.7"L x 9.25"W x 2.36"H
Differential-Balanced Input Topology: (1 pair of inputs)
On-board Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (independent active filter, parallel with amp filter or full-range)
Bass EQ: parametric with variable boost up to 15dB and Remote Bass Control (optional)
Infrasonic Filter: fully-variable 24dB/octave from 15-60 Hz
Output Polarity Reversal: switch permits instant output polarity reversal
Dual mono speaker output connections: accept up to 8ga. wire
+12V and Ground connections: accept 4ga. wire (required)
and sells for 799.99 brand new
Username: Glasswolf
NorthWest, Michigan
Post Number: 4872
on a side note, the 1000/1 puts out quite a bit more than it's "rated" power, as do all of JL's slash series amplifiers.
very nice amp.
are those 12W7s in a JL enclosure?
Home > Message Board > Car Audio > Amplifiers > Archive through October 19, 2004 > 2JL12W7&JL1000/1 4 SALE [ « Previous ] [ Next » ]
