Home > Message Board > Car Audio > Amplifiers > Archive through October 19, 2004 > I really must apologize in advance (n...
Author Thread: I really must apologize in advance (need a bit of advice)
Username: Wastelandgrows
I'm sorry to do this, I really have spent hours trying to figure this out on my own, but I need an amp and can't find a good one. All I need to power is a pair of Kappa Perfect 6.1's and a 10 (or maybe 12) perfect sub in a sealed box. I'm not sure about which sub exactly because I haven't quite sorted out the dual voice cone and 2/4 ohm difference yet and which is right for me. I just need an amp to power those 3 componets and that's it. Sub is up to 375rms and the componets are up 10 100 rms. Thank you for anything you can give me, and I'm sorry that this question is so mundance and elementary and nothing will change that. Peacefulness.
Username: Glasswolf
NorthWest, Michigan
Post Number: 4865
look at the kicker kx800.4
100wRMS x 4 @ 4 ohms
you'll want a single coil 4 ohm sub or dual 2 ohm coil sub.
this will give 100 watts x 2 to the 6.1 set and 400 wRMS to the sub.
all ya need, and all in one amp.
Username: Glasswolf
NorthWest, Michigan
Post Number: 4866
forgot to mention, you'll bridge channels 3 and 4 into one channel for the sub.
Username: Deraticus
DuBois, PA
Post Number: 17
Yeah thats the amp my brother used for his perfects but used a memphis sub instead of a infinity. And it sounds great
That amp looks like it is perfect for my needs, I thank you greatly.
Username: Glasswolf
NorthWest, Michigan
Post Number: 4869
when ya get the amp, set high-pass filter on the front channels (perfects) to about 100Hz, and set the sub channel low pass filter to about 60Hz.
that should work well for XO points
Home > Message Board > Car Audio > Amplifiers > Archive through October 19, 2004 > I really must apologize in advance (n... [ « Previous ] [ Next » ]
