Home > Message Board > Car Audio > Amplifiers > Archive through October 19, 2004 > Wiring help
Author Thread: Wiring help
Username: Njb920
Post Number: 7
i have all of my wires hooked up to my amp except for my REM wire, what is that and where does it go. i cant find out where to hook it up.
Username: Napalmz
MIDWEST
Post Number: 24
you remote wire is for turning the amp on..a switch really..it usually connects to some sort of power that is turned on(ex:igniton)but mostly they run from your head unit to the amp itself so when you turn your radio on the amp will follow...
Username: Glasswolf
NorthWest, Michigan
Post Number: 4813
if you have an aftermarket headunit, connect REM of the amp to REM or PWR ANT of the ehad unit.
if this is a stock stereo, connect REM to a switched 12V igition line.
this tells the amp to turn on and off with the car or the stereo.
Home > Message Board > Car Audio > Amplifiers > Archive through October 19, 2004 > Wiring help [ « Previous ] [ Next » ]
