Thread: What AMP! |
New member Username: Mjv817
Post Number: 4 Registered: Sep-04
| Posted on Friday, October 15, 2004 - 03:19 pm: |
hi, i just order an RE 12 x.xx and i dont know what amp to get to power this sub, will it cost more then 400-500 dollers for the amp??(btw i dont like buying off ebay) and should i just build a box with the specs they got on there website?? |
NorthWest,
Michigan
Post Number: 4664 Registered: Dec-03
| Posted on Friday, October 15, 2004 - 03:22 pm: |
the website plans for a box are good. yes. as for power to an RE triple X 12", give it between 1,000-1,500 watts RMS. if you're limited to under $450-500 for the amp, look at a good class D amplifier, such as Kicker, MTX, or Avionixx.
Post Number: 5 Registered: Sep-04
| Posted on Friday, October 15, 2004 - 03:38 pm: |
would MTX thunder1501D work?? im not limited to 500 but thats all i got right now :/ |
NorthWest,
Michigan
Post Number: 4671 Registered: Dec-03
| Posted on Friday, October 15, 2004 - 09:03 pm: |
yup good amp.
