Home > Message Board > Car Audio > Amplifiers > Archive through October 19, 2004 > Will this work
Author Thread: Will this work
Username: Stoner2oo4
Post Number: 12
Im thinkn about 2 kicker comp VR 12s they are 4ohm subs and i want to run them off a JBL 600.2 and run 300watts@2ohm to each sub...is this possible even though they are 4 ohm subs and how will it affect them?
the load that you are puting on the amplifier will eqill 2 ohms from your 2-4ohm subs, and if i am correct, jbl can handle 1 ohm loads, so you should have no problem, just be sure to bridge the speakers to the amp
Username: Glasswolf
NorthWest, Michigan
Post Number: 4578
1 ohm loads are only possible on the BP series monoblock class D amps.
you'd be better off with the JBL bp600.1 with two 4 ohm subs
other option is to get two of the 2 ohm versions and use your 600.2
Post Number: 14
what if i get 2 JBL 180.2 amps one for each sub and bridge them..thats 360watts@4ohms and only $109 from sounddomain is this too good to be tru?????
Username: Chevy_for_life
Post Number: 73
isnt that a 2 channel amp???u cannot hook both of the channels to the same sub..
Post Number: 16
well my cd player has a mono sub output and it has 2 RCA connectors for it that are on the same channel so couldnt I hook up the positive of one channel and negative of the other channel to the sub..if im not mistaken that would be how to bridge a 2 channel amp ne ways..dont people do this with 2 channel amps?????
Post Number: 92
are u sure that ur amp is acctually bridgeable??????
Post Number: 17
well what does it mean by 360watts@4ohmsX1 BRIDGED
Username: Glasswolf
NorthWest, Michigan
Post Number: 4635
if the CVR subs you have are the dual 2 ohm coil models, you'll have two 4 ohm subs (coils in series)
the two bridged 180.2 amps would be fine for those. one amp per sub.
Home > Message Board > Car Audio > Amplifiers > Archive through October 19, 2004 > Will this work [ « Previous ] [ Next » ]
